Filters
Discussion in 'Projectors, Screens & Video Processors' started by Ghidorah, Feb 12, 2003.
  1. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hello,
    Has any one got their CCR40R filters for the HS10 yet.
    As I went into my local camera shop and he said that the hoyrex 065 85 filter is the same. It looks a lot darker than the one supplied with the PJ. Can anyone tell me if it is the same or put a picture of the CCR40R on the forum?
    Thanks:D
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Its a red as opposed to a magenta and YES it does improve things after calibrating.
  3. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hello John
    Have you got a pic of it as I cant tell if mine will be allright.
    I was given a ring to put it in but i will have to cut it down and try to stick it in, but if it is wrong then it will go back.
    Thanks for the reply
    Ghidorah:smashin:
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    No pic I'm afraid but its a 67mm ring with a fine thread and it just screws into the front of the lens opening.
  5. John_N
    John_N
    You can see elsewhere on this forum where to get the filter from. It's a place called SRB who do filters. The price is £18.
    The filter is CC40R (red) on a 67mm thread (standard fitting) as opposed to the supplied cinema filter which I believe is a CC20M (magenta). The numbers refer to the intensity of colour of the filter so a CC20M is a lighter shade of magenta than a CC40M and so forth.
    It makes the picture better as long as you calibrate the unit afterwards because it makes everything look pink.
    John
