Filters for Panasonic GX7
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by davidpow, Jun 25, 2002.
  1. davidpow
    davidpow
    Jun 25, 2002
    17
    I want to use a polarising filter on my GX7. My problem is that the lens hood has an insertion tab that will not pass through the filter...so I cannot put a polarising filter on unless I leave the lens hood off. Panasonic do not make a "compatible" polarising filter. Has anyone else overcome such a problem with their GX7? Is there any "negative" to leaving the lens hood off?
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,120
    Leicester
    +49
    I've not noticed hoods make any real difference and the stills one that comes with my GX7 doesn't seem to to me.
    Try it without a hood and let us know how you get on.
  3. Guest
    I am thinking of buying GX7. Is this model a good buy?
  4. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,120
    Leicester
    +49
    Depends what you're looking for in a cam,because you might be better off getting a seperate digital camera and then getting a cheaper Panny cam.
  5. Guest
    thanks Wayne.
