filters and lens hood
achoudry
hi,
i've got a canon 450D and am thinking about getting the following:
Hoya 58mm UV Filter
Hoya 58mm Circular Polarizing Filter
Canon ET-60 Lens Hood
i'm not sure if i need both filters. how or when do you use filters? do you keep a UV filter constantly on your lens?
also, any recommendation on other filters or views on the filters and hood i've mentioned above?
nikonuser11
Hi Achoudry, I also have the 450d and got a UV filter from day one, purely to avoid the lens getting scratched plus its easier to clean a £15 filter from spray/rain/muck etc than tentatively try and clean your expensive lens.
The polarizing filter is a must I feel, I've had some great deep blue skys and water surfaces without haze so I recommend getting one.
I've also a hood but havent used it yet, dont really know why/when I should so maybe someone else will highlight the pro's and con's of the hood.
OrbitalPete
Personally I don't use UV filters; the end elements of lenses are well hardened, and are protected by lens caps and hoods most of the time anyway. DSLRs have in-built UV filtering so they serve no purpose other than to protect the lens front.
most of what you want to know about CPLs is summarised here:
Photographic filter - Wikipedia, the free encyclopedia
basically anything with sky or reflections where you can afford to lose a couple of stops.
