Filter questions
Discussion in 'Photography Forums' started by snerkler, Jun 8, 2015.
  1. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Apart from buying the 'special' Lee kit is there another way to be able to use a CPF and ND grad filters at the same time? I don't know if my CPL is threaded (can't be arsed to go look :blush: ;)) but even if it was by the time I've screwed my square ND filter mount on the CPF probably won't be in the right orientation :rolleyes:
  2. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    Yes, buy any one of the 'replica' Cokin P style adaptor holders, relevant sized adaptor ring and a Kood/Cokin CPL. All in it will set you back less than £50 and you'll be able to use the grad and rotate it and the CPL independently.
    • Thanks Thanks x 1
    • Useful Useful x 1
    • List
  3. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Thanks, is this the kind of thing you're referring to? I have a cokin style holder already, but this is the only CPL I can find that I could use in conjunction with it. I couldn't find a cokin kit.
    Polaroid CPL Filter Compatible with Polaroid & Cokin P: Amazon.co.uk: Camera & Photo
  4. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    That's exactly it. It fits into the first thin slot on the holder and can rotate within it. You then drop in the grass in front of it.
  5. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Cool, cheers. Any idea how good it is, I'm a bit skeptical with it being so cheap?
  6. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Funnily enough I got one of those types of sets a couple of weeks ago with a range of ND graduated filters.
    I have only experimented so far not used for any serious shooting. So far so good in the sense that it does what it says. It comes with a range of lens adapters so fits on anything I have.
    Two things to note:
    1. None of my CPLs have threads so no way to combine with one of those unless I use gaffer tape on somesuch ;)
    2. Below about 24mm on the full frame the holder is visible. There are bigger sets to avoid this. Doesn't matter for me but might be annoying if you weren't expecting it.
    Edited - missed out the point I was trying to make - thanks for the tip looks better than gaffer tape :)
  7. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Thanks for this, that's no good to me then as I plan on shooting at 18mm :rolleyes:
  8. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    If You're shooting 18mm on full frame you probably won't even get away with a slim Cokin p holder which basically just has a single filter slot in front of the CPL.
    I've never used the Polaroid filter you linked to. I've got a mix of Kood and Cokin filters and think I probably got the CPL from crooked imaging so worth trying them.
  9. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    There are large cokin systems, Z Pro? I didn't bother as it looked a lot more and I doubt I will take enough pictures below 24mm to need it. If I do find it limiting I might upgrade :)
  10. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Thanks, good point about the holder. The 18mm eq I used it on before was on the Em10 (9-18mm) and the lens diameter was small so no risk of vignetting/seeing the holder. I do have one on these too, but it only has one slot :rolleyes:
    P Size Wide Angle Filter Holder | SRB-Photographic.co.uk
  11. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Yeah, pretty expensive :(
  12. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    That's the correct wide angle holder. It has two slots, the thinnest one nearest to the lens is where you fit the CPL then the wider slot in front is for the grad filter.
  13. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Thanks, is that CPL wide enough then to fit?
  14. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    Yes, the ribbed edge around the outside of the CPL is about half the thickness of the filter so you drop that into the thin slot and the rest of the filter faces forwards away from the lens. You can then turn the filter within the slot by using the ribs to grip it.
  15. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Cheers for this, most helpful :)
  16. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    [​IMG]
  17. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Curiosity got the better of me so I just took a look. For 18mm you probably need the x-pro which is larger again and the basic adopters and filters are about $280 then the cpl to fit is another $200 on its own.... Yep that's why I stuck with P kit....
  18. weaviemx5
    weaviemx5
    Oct 8, 2005
    6,901
    Wirral
    +3,270
    The only issue you might have is that the slim holder may not allow both the CPL and grad at the same time as the CPL can be a tight fit behind the first filter slot.
  19. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    D'Oh, that's what I meant in post #10 when I said it only had the one slot ;)
  20. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    See #17 and prepare to dig deep :)
  21. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Think I'd try hand holding the grad filter in front of the CPL before spending £100+ on a holder :laugh:
  22. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Agreed ... Or gaffer tape ;)
    Looking forward to seeing the shots
  23. shotokan101
    shotokan101
    Jun 16, 2009
    75,862
    33
    Glasgow
    +25,821
    ...but we all know you wouldn't really ;)
  24. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Do you know, I probably would try it knowing me :laugh:
  25. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Well the CPL certainly fits the holder but you can't then add the ND grad filter. I have a 'standard' non wide angle filter holder which has 3 filter slots so can fit a ND grad filter as well but at 18mm on FF you can see the filter holder on the edges of the frame.
    Back to the drawing board :rolleyes:
  26. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Or shoot from 24mm plus or whatever you need to miss the holder?
  27. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Then what's the point of having an 18mm lens ;)
  28. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    Haha well you can still use it for the 95% of the time you don't need a cpl and nd grad at the same time :) cpl on its own, nd or nd grad on own or no filter for architectural shots etc all no problem ! Methinks you rather enjoy finding the problems :)
  29. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,150
    Not at all, shot many a landscape but was just wondering if it was possible. Seems not without spending mega bucks. Would be nice to use both though as I find grad filters pretty essential, but would like that extra punch from CPL without having to 'fake it' in PP ;)
  30. newbie1
    newbie1
    Sep 7, 2009
    3,143
    +2,852
    I agree it's annoying the mega bucks required for those last few mm of focal length :)
