Film Audio Clips
Discussion in 'Movie Forum' started by quarry2006, Apr 26, 2007.
  1. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    Are there any websites that provide downloadable, high quality wav or MPEG film files? I'm specifically after audio grabs from the original Texas Chainsaw Massacre but some stuff from Apocalypse Now, Full Metal Jacket, The Silence Of The Lambs and Hannibal would also be pretty nice.
  2. aprout
    aprout
    Jan 22, 2004
    6,785
    In a world of my own
    +599
  3. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    Marvellous. Thanks for that, aprout, I'll check it out fully when I get home form work tonight.
  4. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    No Texas Chainsaw or Hannibal, sadly, and only one audio clip from Apocalypse Now. The search goes on...
  5. Edward Catflap
    Edward Catflap
    Apr 5, 2005
    100
    +9
    If you get the ImToo DVD audio ripper, you can do it for yourself - provided you have the dvds of course.
  6. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    Yep, I have the DVDs. ImToo, eh? Right, well I'll have a look around for that. Thanks, Edward.
  7. Edward Catflap
    Edward Catflap
    Apr 5, 2005
    100
    +9
    No probs. I tried to provide a link but it ***** a bit of it out, so maybe it's against forum rules or summat. Anyway, a quick google will find it for you. Very good it is too.
  8. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    I've downloaded it but can't really work it out, to be honest. Is there some kind of support menu to help you use it? I don't want to copy the entire soundtrack as one file; just specific bits of dialogue. Will I be able to do this with this program?
    Apologies for my ignorance.
  9. Edward Catflap
    Edward Catflap
    Apr 5, 2005
    100
    +9
    There's support/FAQ's on the website. Just work out which chapters have the bits you want, tick that/those chapters & untick the others, and then extract them. If you wanna edit them afterwards, I can highly recommend this bit of software
    http://www.pistonsoft.com/mp3-splitter.html which is one of the best/easiest bits of software I've ever used. There are other free MP3 splitters available obviously though.
  10. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    Theres some cracking MSG alerts for my PPC on that site!
    Liam:)
  11. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +469
    Cheers, all. Clearly I'm going to need to set some time aside for this!
  12. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,068
    Essex
    +73
    did you purchase it or did you use the free version?
  13. Edward Catflap
    Edward Catflap
    Apr 5, 2005
    100
    +9
    Used the free trial version, liked it & so bought the full version as the trial one only does 5 mins maximum length, which is obviously not enough for songs/clips that are longer.
  14. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,068
    Essex
    +73
    ok! cheers
