Filling the gaps for circa £150
Discussion in 'Photography Forums' started by tontoshorse, Jan 2, 2007.
  1. tontoshorse
    tontoshorse
    Sep 30, 2005
    3,358
    +691
    looking to add an extra lens to my D50 +18-55 kit lens. Most of my shots would seem to indicate a leaning to a wide angle rather than a 200 or 300. But I could be wrong!
    I'd be looking to go 2nd hand to keep the costs down and to lessen the pain if I get the choice wrong.
    Anyone able recommend a good'un? :thumbsup:
  2. Radiohead
    Radiohead
    Dec 24, 2001
    4,418
    Amazingstoke
    +442
    How often do you want to go wider than 18mm? My inital thought is that buying, say, a 12-24 gives you nothing over 55mm, which is still pretty short even on a 1.5x crop.
  3. tontoshorse
    tontoshorse
    Sep 30, 2005
    3,358
    +691
    Hmm, you're right with the 55mm and over. Perhaps i can't see the wood for the trees.
    The choices are quite bewildering!
    I had even considered the 70-210 Af nikon second hand!
    So if presumably if the longer lens gets more use, but the financial constraints still apply...(which rules out a VR!)
    Anyone able to suggest a good'un:D
