files larger than 4gb won't play on tv or ps
richmoor1
i have lots of my films which are stored on my external hard drive connected to my mac. i wanted to dispense with my dvds as they were taking up too much room. i now have quite a large library having spent the last few weeks doing this. I should have investigated first! it all seemed so easy and logical!
my plan was to drag them to a usb stick and plug them into my new samsung tv or ps but the 4gb limit is proving to be an obstacle.
Does anyone know how i can get around this problem. Currently my only option is to copy back to dvd which defeats the whole point.
i can stream via wifi but the pictures are jerky and not consistent.
my tv and ps are too far away to connect via ethernet.
Help!
anorax25
Use Homeplugs to connect TV/PS3 to network and stream that way.
Unfortunately, it appears that most Smart TVs and certainly the PS3 only recognises FAT32 drives which, as you have discovered, will not allow files larger than 3.9GB.
I have a couple of Dune Media players connected to the network via Homeplugs and in turn to my NAS and it all works flawlessly, even with large files.
Col.
anorax25
Just make sure you get a step up from the basic models i.e. AV200 or higher, depending on your budget.
The basic ones tend to be 100Mb/s which is okay but not really future proof.
They also have to be plugged directly into a Mains socket as most extension leads have smoothing circuitry which strips out the data signal. I'm told that cheap extension leads from places like Aldi, Poundland etc., tend to work as they don't have the smoothing circuits built in but, that's anecdotal info' only.
richmoor1
Problem solved! happy days finally years of trying to overcome wifi issues are over! It was so easy as well, no phaffing trying to get this to sync and all the other guff that normally makes me tear my hair out.
Thanks so much, I can now get on with my life!
anorax25
Glad it's all sorted!
Col.
⭐ Bowers & Wilkins 600 S3 Home Theatre Speaker System Review
Back
