file reallocation with nero 6
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamdoughnuts, Nov 8, 2004.
  1. jamdoughnuts
    jamdoughnuts
    When try to burn a project using nero 6 i get the above error message.It says one of more files,mostly VOB files do not belong to the corresponding ifo file. I have burned many projects before in this way with no errors. The only difference with this project is that it is 1hr 41 minutes long, usually my projects are under the hour. This disc will play on my DVD player however it sticks at the last chapter. The dvd folder was created with studio 9. It took about 6 hours to render the 1hr 41 min project so i am trying to avoid doing iy again. I have enclosed the nero burning log.
    Any help would be greatly appreciated
    Thanx in advance
    :lease:
    jam
    File reallocation error with nero 6 this is the log.
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 14/08/2002 15:03:36
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 28/07/2004 16:51:12
    Nero version: 6.6.0.1
    Recorder: <PHILIPS DVDR1640P> Version: P2.0 - HA 3 TA 1 - 6.6.0.1
    Adapter driver: <atapi> HA 3
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <_NEC DVD_RW ND-1300A >Version: 1.0B - HA 3 TA 0 - 6.6.0.1
    === Scsi-Device-Map ===
    DiskPeripheral : ST380011A atapi Port 0 ID 0 DMA: On
    DiskPeripheral : ST3120026AS atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : _NEC DVD_RW ND-1300A atapi Port 3 ID 0 DMA: On
    CdRomPeripheral : PHILIPS DVDR1640P atapi Port 3 ID 1 DMA: On
    === CDRom-Device-Map ===
    _NEC DVD_RW ND-1300A E: CDRom0
    PHILIPS DVDR1640P F: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 1022MB (1047276kB)
    Free physical memory: 639MB (655236kB)
    Memory in use : 37 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    8.11.2004
    UDF/ISO compilation
    09:11:40 #1 Phase 112 File dlgbrnst.cpp, Line 1853
    DVD-Video files reallocation started
    09:11:40 #2 DVDREALLOC -24 File DVDVideoCompilation.cpp, Line 1183
    One or more files (mostly VOB file(s)) do not belong to the corresponding IFO file
    09:11:40 #3 Phase 115 File dlgbrnst.cpp, Line 1853
    DVD-Video files reallocation failed
    09:12:05 #4 Phase 132 File dlgbrnst.cpp, Line 1853
    DVD-Video files compliance ignored
    09:12:05 #5 Text 0 File Isodoc.cpp, Line 6165
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    09:12:05 #6 Phase 111 File dlgbrnst.cpp, Line 1853
    DVD-Video files sorted
    09:12:05 #7 Text 0 File Reader.cpp, Line 127
    Reader running
    09:12:05 #8 Text 0 File Writer.cpp, Line 122
    Writer PHILIPS DVDR1640P running
    09:12:05 #9 ISO9660GEN -11 File geniso.cpp, Line 3286
    First writeable address = 0 (0x00000000)
    09:12:05 #10 ISO9660GEN -11 File geniso.cpp, Line 3286
    09:12:05 #11 Text 0 File Burncd.cpp, Line 3117
    Turn on Disc-at-once, using DVD media
    09:12:09 #12 Text 0 File DlgWaitCD.cpp, Line 256
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 2153295 (478:30.45, 4205MB)
    09:12:09 #13 Text 0 File DlgWaitCD.cpp, Line 268
    Write in overburning mode: NO
    09:12:09 #14 Text 0 File DlgWaitCD.cpp, Line 2309
    Recorder: PHILIPS DVDR1640P, Media type: DVD+RW
    Disc Manufacturer ID: RICOHJPN, Media Type ID: W01, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 0
    09:12:09 #15 Text 0 File DlgWaitCD.cpp, Line 430
    >>> Protocol of DlgWaitCD activities: <<<
    Insert empty disc to write to.
    (Medium in drive: DVD+RW. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R9 Double Layer.)
    This disc is not empty.
    Accessing disc...
    09:12:09 #16 Text 0 File ThreadedTransferInterface.cpp, Line 844
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2153296 (2153296) = #2153296/478:30.46
    relocatable, disc pos for caching/writing not required/ required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2153296 blocks [PHILIPS DVDR1640P]
    09:12:09 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1047
    Prepare recorder [PHILIPS DVDR1640P] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4409950208, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2153296 | lead-out | 1 | 0x00 | 0x41
    09:12:10 #18 Phase 24 File dlgbrnst.cpp, Line 1853
    Caching of files started
    09:12:10 #19 Text 0 File Burncd.cpp, Line 4003
    Cache writing successful.
    09:12:10 #20 Phase 25 File dlgbrnst.cpp, Line 1853
    Caching of files completed
    09:12:15 #21 Phase 36 File dlgbrnst.cpp, Line 1853
    Burn process started at 2.4x (3,324 KB/s)
    09:12:15 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2497
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    09:12:15 #23 Text 0 File Cdrdrv.cpp, Line 8281
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+RW (9), Part Version: 2
    Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 0 h
    Media type ID: W01
    Number of Physical format information bytes in use in ADIP up to byte 63: 57
    Media Specific [16..63]:
    00 00 00 52 49 43 4F 48 - 4A 50 4E 57 30 31 01 39 ...RICOHJPNW01.9
    23 00 8A 79 6A 02 1A 00 - 8E 7A 6A 02 1A 00 8C 7A #..yj....zj....z
    6A 02 1A 23 13 10 F0 10 - 00 00 00 00 00 00 00 00 j..#............
    09:12:15 #24 Text 0 File dlgbrnst.cpp, Line 1711
    Set remaining time: 22:26,198 (1346198ms) -> OK
    09:12:15 #25 Text 0 File DVDPlusRW.cpp, Line 632
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    09:34:51 #26 Text 0 File WriterStatus.cpp, Line 116
    <PHILIPS DVDR1640P > start writing Lead-Out at LBA 2153296 (20DB50h), lenght 0 blocks
    09:34:51 #27 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    09:34:51 #28 Text 0 File dlgbrnst.cpp, Line 1711
    Set remaining time: 0:00,000 (0ms) -> OK
    09:34:51 #29 Text 0 File dlgbrnst.cpp, Line 1711
    09:34:51 #30 Phase 161 File dlgbrnst.cpp, Line 1853
    Burn process completed successfully with warnings
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 14/08/2002 15:03:36
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 01:27:50 (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
