File management questions for K750i - need some help
Discussion in 'Mobile Phones Forum' started by SanPedro, Aug 6, 2005.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Using a K750i plugged into a Mac Mini via the USB cable.
    Just a few questions...
    How do I copy files from the phone memory onto the Mac?
    is a Bluetooth dongle the only way?
    How do I delete music files from the memory stick? I press delete and the file still appears? what the fudge is going on? I copied the files to the memory stick from iTunes and the name of each file appears twice in the media player list. Also... when I try to create a playlist it won't let me add any of these files. The files seem to have been saved with the .m4a as the file extension. They play ok though.
    Files with the .mp3 extension I can add to a playlist.
    is it possible to move files from the internal memory to the memory stick... as that way I can drag and drop them from the mem stick to the Mac.
    Any advice greatly appreciated.
    CL
