file extention tips for music and thumb pics
Discussion in 'PS Vita Forum' started by VinceVega, Sep 10, 2005.
Tags:
  1. VinceVega
    VinceVega
    Play itune AAC files and change your thm's
    make sure you can view your file extentions by changing your windows folder options.
    My computer -> tools -> folder options -> View tab and just make sure hide extensions for known file types is unchecked so you can see all file extentions.
    Then with your itunes .m4a you can just literally rename the file extention to .mp4 drop it on ya mem stick and ya psp sees it.
    You can also change your THM thumbnail images you get for your video9 movies.
    Create a 160 x 120 pixel image at 72dpi in Photoshop or similer application to refrence your film e.g. starwars logo or what ever your film is.
    Then save it as an rgb jpg. Then copy paste the file name of your original .THM file into the jpg file name you have just made so its the same, and then replace your old .THM file with your new
    Just drop it back in the correct place in your movie folder in your psp mem stick and when you view your movie on your psp mem stick the image will be your new one.
    cool
    later
    VV
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,464
    +6,239
    you can also open the THM file in phot-editing program, and change the pic to desired, at above pixels
