etaf
I'm looking to replace a small cheap headphone amp ( runs on 2x AAA batts ) I purchased from Maplin a few years ago to run in the car and on a pair of headphones
used
On an apple Touch and a Nano
On Car Stereo via the Aux input - current amp works fine
in the car I also have a USB charger
Sennheiser PXC-450 Noise reduction headphones
Bass boast maybe useful - when on noise reduction loses a bit of bass
I have been looking at the Fiio E range and yep, a little confused
I would like to use while charging - I know some do - But if theres a big advantage for the modek that does not charge than happy to put up with that
I like the extended battery life 80hrs mentioned on one of the models
I will also purchase the ipod cable, as this is mentioned in a few reviews as improving quality
so what do i know
I'm tempted by the
E7 - £50
Batt life 80 hrs ,
no noise hiss,
can NOT be used while charging
150mW 16ohm
E6 - much cheaper £20 -
still no noise hiss,
can be used while charging
battery life 10hrs -
poor build quality compared to F5 - but F5 has hiss
E11 Approx £40
battery life 10hrs
battery that is easily replaceable
300mW - 16ohm - so is this really twice the power of the E7
E10
now very confused
so a little confused on what will work best
Do not want for PC sound - just the headphones
any help will help - thanks
also any alternative suggestions
used
so what do i know
I'm tempted by the
E7 - £50
Batt life 80 hrs ,
no noise hiss,
150mW 16ohm
E11 Approx £40
battery life 10hrs
E10
now very confused
