FIFA 07 - ye olde Xbox version
Discussion in 'Xbox Forums' started by TurquoiseShark, Apr 30, 2007.
  1. TurquoiseShark
    TurquoiseShark
    The old black box version of FIFA 07 is now backwardly compatible, shame it didn't happen sooner because the gameplay is vastly superior to the 360 version and for those who like completeness, you get ALL of the teams, players as opposed to the handful of players you get in the 360 version.
    Works through VGA too.
  2. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    Cornishman living in Cheltenham, following the mig
    +267
    GREAT NEWS! Cheers mate! :D The old Fifa is soooo much better than the new poo!
    Linky
  3. ScarySquirrel
    ScarySquirrel
    Dec 3, 2006
    670
    28
    Kent, England
    +43
    Fantastic, I held off getting it because I wasn't sure about the VGA aspect but this is great news.
    Quick question though, in FIFA 07 on the XBOX you use BLACK for chip shot and WHITE for that little close control this, is this now mapped to any other buttons, if so, which ones?
  4. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    I'd imagine they'll be mapped to the RT/LT shoulder buttons. Will confirm once I've had a go tonight.
    Hopefully this'll mean we can all play online too. Great news as it's infinitely more playable than the 360 footy games. No need to buy the UEFA game now as this has hundreds of teams and a decent career mode :)
    Good work Microsoft, took long enough but at least they've done it!
  5. jayd
    jayd
    Nov 28, 2005
    6,780
    UK
    +1,554
    I tried to play it, and found it to be a jerky load of crap. I'm using component @ 720p set to 60Hz. Not sure if that makes a lot of difference but it looked really really bad.
  6. TurquoiseShark
    TurquoiseShark
    I found it to play smoothly through VGA, however some of the cut scenes are blurred, the game itself played fine.
    Don't forget you are playing a last gen game, while the gameplay isn't upto much on the 360, you may have got used to the better graphics.
  7. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    Yeah, I must admit that it seemed very jerky online - possibly due to my broadband connection?
    Other than that, the game played very smoothly in-game. The only issues I noticed were with the cut scenes which now make my eyes go funny!
    Still to be able to play with that depth of teams though, why didn't they include them in the 360 version? Here's hoping they'll be around for FIFA 08!
  8. ScarySquirrel
    ScarySquirrel
    Dec 3, 2006
    670
    28
    Kent, England
    +43
    Also hoping that in FIFA 08 they add some tricks and sort the shooting out, oh and the fact that you get sent off if you breathe on someone.
  9. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    Yeah, agreed. Must confess that almost all of my goals in the Champions League game are the "finesse shots". Found it almost impossible to score outside the box. Anyone else found the same?
    (Should probably be on the UEFA thread!)
    Hopefully FIFA 08 will be the business, but FIFA 07 on the original Xbox is still one of the best games that will now work on the 360. Along with Evo 6 I'd argue...
  10. ScarySquirrel
    ScarySquirrel
    Dec 3, 2006
    670
    28
    Kent, England
    +43
    I finally got this and it is great. But I can't play online because I am connected via VGA. When I go to 'Xbox Live' it tries to update then says that my VGA doesn't support PAL-50 and it goes back to the dashboard. Does anyone know a way around this so I can play online with VGA?
  11. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    Blimey, haven't a clue to be honest mate. My techie knowledge is lacking slightly!
    For what it's worth, the online game seemed really jerky though, and the three games I tried to play have all disconnected after about 30 seconds - admittedly, this could've been my opponent's refusal to play against me with a [email protected] connection.
    Has anyone else had the same? Just so I can isolate my connection as being the problem..
  12. blisteringblue
    blisteringblue
    Jun 13, 2004
    921
    Bolton
    +75
    Had the same issue and you need to do the following
    1. Connect up a component cable (or even the stock composite cable/scart)
    2. From standard dashboard goto system display settings
    3. Change Refresh from PAL-50 to PAL-60 and save settings
    4. Connect VGA backup and it should take the new PAL-60 settings
    Worked a treat on my Toshiba LCD, NBA 2k6 would not work via VGA on PAL-50 but works just fine with VGA and PAL-60
  13. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    Nice guide, I wonder if there's any scope for M$ doing something about the replay visuals, wouldn't have thought so now that the game itself works, but it is a bit of a pain having to squint at the screen every time I concede a goal!
  14. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    I was going to get this, but I think I wait until Fifa 08.
  15. steviebwoy
    steviebwoy
    Aug 30, 2006
    3,802
    +267
    No release date for Fifa 08 though is there? Might not even be until the turn of the year? Not sure mate, but you can get the XB1 version of FIFA 07 for about £15 pretty easily. Well worth it in my book.
