Flyboy583
Hi All,
Just a quick question as I seem to be getting conflicting info courtesy fo Google..
I will be running an HDMI cable to my Projector as part of my build. Distance from equipment to Projector conservatively will be in the region of 6 - 7M
What I am trying to achieve is to ensure I use the correct quality cable that will future proof myself. (4K / 8K ect)
There seems to be a suggestion for distances greater than 5M I should use a Fibre Optic HDMI cable?
Cold I just ask for some clarity and advice here? Should I invest in a Fibre Optic cable? Will the added cost provide ultimately benefit?
And lastly, any suggestions on what type of cable (Fibre Optic / Normal HDMI / specific manufacturer?) I should consider buying?
Thanks in advance!
Thanks in advance!
