Fibaro Z wave
Lynch1
I am currently renovating my 3 bed two reception room semi detached house. i am looking at putting in some Home automation. I have came across Fibaro and think this is the best option but not sure. I am looking at something that is easily set up and not loads of coding todo like control 4.
Lighting
I am looking to control all lighting from a iPhone or iPad for 3 bedrooms, 2 living rooms kitchen hall and two separate outside lights. i am also wanting to keep the light switch on the wall so if i don't have my phone on me i can still turn the lights on and off
Cameras
I am looking a putting cameras up to, I see you can wire ip cameras up to the fibaro does these wire straight to the fibaro or do you need a dvd first i would like these to record also.
Alarm
Does any alarm work it or do you need a certain type. I don't mind keeping this separate
Sonos
I was going to put sonos into the living room, kitchen two bedrooms and bathroom not sure if this will work with sonos, i have looked with sonos and looks easy to set up. If you get the sonos connect you can play music from your phone can you have a storage device connected to this and can different rooms play different music
Thanks J
We primarily now install Fibaro Zwave solutions and highly r commend the system
Lighting
With Fibaro you can control via standard switches, smart phone, timers, motion detectors even proximity via geo tagging
You will probably need deeper back boxes 48mm for the modules.
Cameras
The cameras aren't wired to the Fibaro but into the router or network switch which is linked to the Fibaro home centre. Fibaro home centre doesn't record put can take snapshots. If you want to the video record you would need a NVR
Alarm
That's a trickier question as it depends what functionallity you require.
Sonos
Yes Sonos works with Fibaro and sonos will do exactly as you say
Drop me a line and I can go through it with you in more detail afte the holidays
Seb
RajP
As Seb said, Fibaro does pretty much what you need. I have had Fibaro HC2 for almost 3 years now and haven't looked back.. pretty much does what I need my home automation system to take care off.. even though I have CCTV, Alarm and Sonos, I haven't integrated those with Fibaro as I want to keep these specifically independent.
R121
I am currently renovting a five bed/four reception room house and I was going to spend alot of money on Control4 thanks to Seb's recommendation I purchased a Fibaro HC2 and 100 lights and a raft of Fibaro stuff. I have been testing all the kit for a few weeks and it seems reliable and its best of all its the system is expandable.
