Question Fibaro Dimmer2 Retrofit into existing 2-Way/Intermediate Switches
eddiem74
Looking for any Fibaro Dimmer2 Retrofit expertise...
Dimmer 2 | FIBARO Manuals
So my house has various 2-Way/Intermediate Switching as per the below diagrams.
I am trying to retrofit install Dimmer2's however am struggling to find a wiring option that does not result in me losing all switches bar one.
I was looking at various wiring diagrams here:
APNT-112 - 2-Way Lighting Using Fibaro Dimmer 2 | Vesternet
Anyone done this and found a way?
eddiem74
eddiem74
You may want to question who wired the house!
It is the way wiring is done here in Ireland. I have a 2nd electrician in currently and he confirmed the wiring is per the "norm".
So it is looking like I could make 1 switch work by sacrificing all others in the chain which is not ideal or practical.
Any other ideas/suggestions from your experience/knowledge?
eddiem74
You could put a 2nd module behind the other switches , or even a Fibaro door window sensor to act as a controller
How would using a 2nd module help/work...as I would still be missing required wires at each switch, no? How would it be wired?
Are you thinking 'association' i.e. linking modules 1 & 2 so they know each others state? Would wiring still not be an issue?
eddiem74
If you use the door window sensor module you wouldn't need any wiring as battery operated , and associate the two modules
But my existing wiring would not let me add a dimmer2 unless I sacrifice the other wall switches to join all the cables so I have a live and switch wire to connect to the dimmer2 in the one back box.
You are then saying use a door sensor to trigger it?
My main query was around seeing if there was a way to make something work without rewiring so I don't lose to many switches as I need them in case of dinmer2 module failure.
Please don't shoot the messenger ! I know your electrician says it's standard but unfortunately not that compatible with Fibaro and Fibaro supports a lot of wiring configurations . I will have another look at the wiring to see if any other ideas .
The door window sensor isn't used as a door window sensor just as a Zwave wireless controller fitted to a switch as it has an auxiliary input . Wouldn't actually need any of the existing cables at all but could control that lighting circuit by association
eddiem74
Please don't shoot the messenger ! I know your electrician says it's standard but unfortunately not that compatible with Fibaro and Fibaro supports a lot of wiring configurations . I will have another look at the wiring to see if any other ideas.
Would never shoot you Seb, your expertise and advice is to valuable. :thumbsup:
Yes my wiring seems to be the "norm" where electricians were not instructed to wire for Home AV which when my house was built 12+ years ago I would not have even known what that was...:lesson:
Any additional ideas or suggestions welcome but it seems to be a case of running more wires or losing switches to be able to use wires between switches to complete the switch live connection. This might not be a major disaster for the 2-way switches however the main intermediate switches control the landing lights which has 4 wall switches in total, so I would lose 3 switches if using existing wiring.
Thanks again.
Certainly don't come across it in the UK but lets not argue lets find you a solution
1st question do they actually work as they are wired now, as cant quite get my head around the 3 way one
eddiem74
I know...it's the "irish way" it's weird, I even verified on an Irish electrical forum in addition to my electrician telling me.
Yes everything works and the 3 way actually has 4 wall switches in the mix just used 3 in the diagram to simplify the explanation. Electrician verified the wiring and provided me the drawings to help explain to see if anyone had ideas. If you have any doubts I can ask him.
Its I think the American way after some basic research, but ive forwarded it to a couple of electrician and Fibaro experts so hope to get some answers.
The window/door sensor aux input concept would still work but doesn't help you if the main dimmer module fails
eddiem74
Thanks, appreciate you reaching out to contacts. The window/door sensor could not be mounted in back box though, right? It's to big or?
Vesternet have got back to me also:
Unfortunately it appears you’re one wire short. The Dimmer does need to be wired to both Live and the Output and there’s no way around I’m afraid :-(
The attached diagram would work but you have no COM wire between both switches.
If you have no way of running an additional wire I would suggest to:
  • Install the Dimmer on the first switch location with the Wall Switch
  • Disable the other 2 wall switches and use 1 of the 2 wires to connect S/L to light
  • Use Nodon wall switch at other switch positions to control the Dimmer 2 via Associations - http://www.vesternet.com/z-wave-nodon-wall-switch-3074
eddiem74
Had answers back and unfortunately without rewiring there is no way you can use the switches.
So options are door/window sensors with battery , or universal sensors with Power supply or a zwave remote wireless switch
Door window sensors are not that big and thinner than a module
On another note, finished getting our Amazon Dot converting voice commands into Fibaro Scenes or module control, so at last we have a reliable voice activated system for just over £100, plus the Dot is a nice speaker as well.
Needs a RaspberryPi with HA-Bridge on it bridge but relatively simple once you realise all the shortcuts weren't worth it and just follow the guides to the letter.
