D
duracell
After installing and configuring FFDshow and Theatertek I get a great picture but it stutters. If I disable the FFD show post processing it's as smooth as Silk. Obviously the re-sizing and Blur and Denoise are requiring too much Horsepower.
However.............. The machine is an Intel 3.2Ghz P4 with 1Gb ram on a Shuttle 915 chipset MoBo, with an ATI 9550 (256 Mb) outputting via DVI. Personally I would have thought this powerfull enough but go figure.
I was really impressed with the results, between stutters, and would like to press on and build a purpose made HTPC. Anybody know where the above machine falls down on performance?
Could I stop the stutters with a new MoBo and CPU (maybe dual core) or does the Graphics card have to be upgraded to PCI Xpress, or both?
Regards, Dura.
Regards, Dura.
