FFDshow with Zoomplayer
Discussion in 'Desktop & Laptop Computers Forum' started by cablecar, Jan 14, 2005.
  1. cablecar
    cablecar
    Nov 13, 2002
    203
    Wellingborough
    Can anyone help with setup for Zoomplayer using FFdshow filters and Powerdvd 6 filters to play Pal titles.
    I think I need a registry hack.
    Do I also need any special settings in FFdshow.
    Any help greatly appreciated.
    Cablecar
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    'Fraid I've never seen a registry hack for the PowerDVD codecs .. Sonic, nVidia and WinDVD yes, but Cyberlink no.
  3. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    As Kragorn has said, and when i was using the PDVD codecs (V5) i didnt have to change anything in the registry to play either NTSC or PAL material.
    I do have to for the NVidia codecs though.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Interesting Inzaman, I've always believed the problem with PAL to be that FFDSHOW needs telling it's handling PAL and that 'telling' is done by the codec, hence the need for a registry setting for the codec .. if you really did play PAL iwth PowerDVD without such a setting (which I have no doubt you did :) ) thenit implies the codecs work it out for themselves.
    Cablecar: can we just be clear, you CAN play NTSC DVDs with FFDSHOW, right? And you CAN play PAL without FFDSHOW?
  5. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Yes Kragorn the only time i have had to change the registry settings was when i started to use the NVidia codecs.
    At first it they wouldnt work with PAL so i had to insert the PAL line into the registry. With PDVD codecs there was no registry setting changes required, i will just double check once i get a new hard drive as my hcpc has recently died :rolleyes:
  6. Gerbil
    Gerbil
    May 20, 2002
    265
    Newbury
    +23
    Have a look at this thread on the ZoomPlayer support forum.
  7. cablecar
    cablecar
    Nov 13, 2002
    203
    Wellingborough
    Thats for all the interest and replies.
    Yes I can play Ntsc with FFdshow filters, but not Pal.
    Cablecar
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Well apart from that registry setting I've never had any problems playing PAL DVDs .. that forum discussion Gerbil linked to seemed to cover it. :(
  9. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    cablecar, if you are wanting to play pal material then use the pdvd 5 codecs or even better buy the nvidia ones, they both definitely work as i have used them, am currently using the nvidia one.
    It could be an issue with the pdvd 6 codecs and zp/ffdshow.
