ffdshow & WinDVD 6 - Can it be done & would I want to ?
Discussion in 'Desktop & Laptop Computers Forum' started by Tempest, Sep 16, 2004.
  1. Tempest
    Tempest
    Jan 11, 2002
    7,283
    Horley, Surrey
    +2,535
    Never tried ffdshow (just read a bit about it here)
    Can it be used with Intervideo's WinDVD 6
    and would it make any difference ?
    If it can be used with WinDVD 6
    Could anyone advice how ?
    Many thanks
    ====== Edited ======
    Just looked at using ffdshow with some other DVD playback software, and in the options of other DVD playback software progs you have options to use external renderer (for example) there does not seem to be any option in WinDVD to do this kinda thing.
  2. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +86
    As far as I know, you cannot use FFDShow with WinDVD on it's own. You must use Zoom player with WinDVD filters
    Check this out at AVS
    Now you know as much about it as I do :D
    I use Theatertek with FFDshow...very simple to use
    Conor
  3. Tempest
    Tempest
    Jan 11, 2002
    7,283
    Horley, Surrey
    +2,535
    Thanks for that Comer.
    I can't run TheatreTek anymore.
    My new machine is an AMD64 running XP home and SP2 installed.
    On my old machine it ran fine, on my new machine TheatreTek opens and closes instantly. No idea why. Poss Service Pack 2 ?
    Is it actually worth messin around the FFDSHOW in the 1st place.
    Will it actually make WinDVD look any better ?
  4. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +86
    It would be worth asking about TT and SP2 on the theatertek forum. I have not installed SP2 on my HCPC yet as I have also heard of problems with TT and the upgrade.
    I ahve tried all the resize stuff and really could not notice any great difference so I just use gradual denoise and sharpen and they do improve the pq a bit. It's really down to opion as to wheather it is worth it or not
    About WinDVD6, have you tried it Hidef material and if so how does it perform. Also is there an option to adjust overlay in WinDVD6
    Conor
