FFDShow picture sizing
Discussion in 'Desktop & Laptop Computers Forum' started by MikeFish, May 19, 2005.
  1. MikeFish
    MikeFish
    I'm trying out Meedio.
    When I use the built in video player the picture displayed on my screen is correct. All the menu screens are also correct.
    The problem occurs as soon as I tick the check box that says 'use ffdshow'.
    Then, when I watch a film from my hard drive (my movies) the picture has black bars all the way round the screen.
    If I turn off ffdshow everything is fine again.
    I am using vmr9 with Nvidia codecs (withinh meedio).
    The only part of ffdshow that is turned on is the blur & nr. If I tick resize & aspect the picutre gets even smaller (or zooms in far too much). I just can't get it right.
    Any suggestions?
  2. MikeFish
    MikeFish
    By the way, my plasma is connected via the component connections on my gigabyte 6600gt graphics card. Native resolution of screen is 1024 x 1024.
    Component is being fed at 720p.
