ffdshow on pioneer 434/435
Discussion in 'Desktop & Laptop Computers Forum' started by rupa, Nov 8, 2004.
  1. rupa
    rupa
    hi
    I am new user.
    I have some difficulty to set theatertek with ffdshow on my pioneer.
    I don't find a good image and so i answer if there are somebody who find a good setting.
    thank you
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Need a bit more info to start with I think :) .. which version of TheaterTek and FFDSHOW? What CPU have you got? What FFDSHOW filters are you using?
    Once we know what sort of HTPC you have and what you're trying to achieve we should be able to help. :)
  3. rupa
    rupa
    My htpc:
    pentium 4 2.8c
    ram 512 mushkin level 2
    ati radeon 9600 pro 128
    Hd sata 80 Gb
    DVI to HDMI gefen 2 meters
    refresh 50Hz
    pioneer 435 HDE
    powerstrip
    Theatertek 2.02
    ffdshow last vesrion of october sse2
    filter
    black n&r denoise 3d. 0.5-1.5-6-HQ
    resize 1440*1112 lanzcos default choma 1.5 luma 1.5
    output Yv12
    I use for my test star wars 2 and i see a lot of rumour at the begin when Anakin and other Jedi kill two worms.
    Thank you
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Okay, so what problems do you have with the image? I use pretty much the same hardware and software (only resize though to 1280x720).
  5. rupa
    rupa
    I have much rumour in dark scenes i try to change resize but i don't correct the problem.
    What version of pioneer do you have?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Ah, I said 'pretty much', the PC is similar but I'm using a projector so different display.
    Not sure what you mean about 'rumour', that's not a term I'm familiar with, but I know next to nothing about plasmas.
  7. rupa
    rupa
    Sorry for my english.
    I see noise and big pixel on dark scenes
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Hey, no problem with the English, I just wondered if there was a term I'd not heard before. :)
    Noise and blocking .. have you calibrated your system? Could it be black clipping perhaps? I have some idea where noise comes from with DLPs but plasmas I don't really know.
    Anyone plasma FFDSHOW users round here shed light on thi? :confused:
  9. philipb
    philipb
    Mar 6, 2002
    2,097
    63
    Swindon
    +175
    Bit of a longshot, but try lowering the gamma setting in the video controls of TT2. I found this helped when I saw lots of rubbish in dark areas of homemade DVDs.
