FFDSHOW "ForcePal" switching using Girder
Discussion in 'Desktop & Laptop Computers Forum' started by Tim Cooper, Oct 28, 2004.
  1. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    Chap's,
    I never bothered with FFDSHOW & TT 1.5x because i hated the hard artificial look, with TT 2 (02) however with it's better deinterlacing, it is now the time to start tweaking :)
    One of the biggest pitfalls, IMO, of FFDSHOW is that it doesn't recognise PAL ,you have tell it it's receiving a PAL signal, the other major hurdle is trying to tell FFDSHOW, TT & Girder to switch the "ForcePal" option on & off using via a Pronto (as in my case)
    There is a nifty plugin for Girder called RegSetValue 1.7 which allows (very simply) to add registry entries.
    With this plugin i can show you how to switch the ForcePal option in TT 2.02 only.
    1. Download the plugin, unzip the program (to desktop) remove the "RegSetValue.dll" & the "Switchwave.gml" from their respective folders & place both in your Girders plugin folder.
    2. Open Girder go to file>settings, in the settings window go to the plugins tab scroll down to "RegSetValue" & tick it, also tick "Auto Enable Input Device" apply & ok, dont forget to save i.e file>save.
    3. Next open Edit>Add Multigroup, rename it, i.e "FFDSHOW PAL", right click on your new multigroup & select "Add Command" from the context menu, rename this, i.e force pal, keep this command highlighted & select the Girder "Plugins" tab, highlight RegSetValue, press the "Settings" button & in the "Key\Name" box add this value:
    HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Filters\Video\ForcePALConnection
    Hit the "REG_DWORD"radio button.
    In the "Value box" add this:
    00000001
    Apply & ok.
    5. That's the first bit done, i like to have a wait command before each command is executed to do this right click on your "Multigroup" the one named FFDSHOW PAL ;) from the context menu "Add Command" rename it "wait" from the Girder tab select "Window" & from the drop down tab select "Wait" in the "X/Timeout[ms]" type this value:
    10000
    Next tick "Wait for Window"
    6. Right click on your "Multigroup" "FFDSHOW PAL" from the context menu "Add Command" rename this to "ffdshow on" keep this highlighted & from the Girder tabs select "Plugins" highlight RegSetValue, press the "Settings" button & in the "Key\Name" box add this value:
    HKEY_LOCAL_MACHINE\SOFTWARE\TheaterTek\TheaterTek DVD\Video Enhance
    Hit the "REG_SZ" radio button.
    ffdshow MPEG-4 Video Decoder
    Apply & ok.
    7. Now add another wait command just copy your original & paste in your "Multigroup" FFDSHOW PAL ON.
    8. Nearly there :smashin: Right click on your "Multigroup" FFDSHOW PAL" Add Command" from the context menu rename it "pp select" keep this highlighted & from the Girder tabs select "Plugins" highlight RegSetValue, press the "Settings" button & in the "Key\Name" box add this value:
    HKEY_LOCAL_MACHINE\SOFTWARE\TheaterTek\TheaterTek DVD\PostProcessing
    00000001
    Apply & ok.
    9. Right then that's the Pal bit sorted only the NTSC to do :boring: only kidding :lesson: Copy your "Multigroup" "FFDSHOW PAL" & rename it to "FFDSHOW NTSC" highlight "force pal" & rename it "force ntsc" this is the only command that will need to be changed.
    In the new "Multigroup" "FFDSHOW NTSC" select "force ntsc" keep this command highlighted & select the Girder "Plugins" tab, highlight RegSetValue, press the "Settings" button & Hit the "REG_DWORD"radio button.
    00000000
    Apply & ok.
    Don't forget to save the new config in Girder i.e save.
    Now test your new multigroups & add the IR commands & voila! easy switching of the ForcePal problem from the comfort of your armchair.
    There are other post processing options in TT2x & all can be implemented in exactly the same way.
    It all seems a bit daunting, do it, it's not a lot of time (30 mins max) & it works, beautifully.
    I'm tweaking like mad now with FFDSHOW & the images i'm getting are sublime but that's for another thread :cool:
    Here endeth the lesson if i seem a little patronising to the "old hacks" here i'm sorry........& tough :D
    HTH.
    Tim.
  2. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    you could of course use anydvd , when you insert a dvd it detects whether its ntsc or pal and then runs whatever you tell it to accordingly (reg file, batch file etc). Very easy to use and works evertime and is totally hidden in the background (many thanks to the guys that told me about this program)
  3. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    yes, I've been using this anydvd-style switching (actually I use another program but it does a similar thing) for ages. Definitely simpler than Girdir and also requires no input from me whatsoever :)
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Unless of course you play DVDs off a hard disk and don't store them in a mountable ISO image. :)
  5. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    Good point, however i've also done more multigroup/macro's for the other post processing method as well as turning ffdshow on/off, turning on/off overlay turning on/off dxva vmr7 & vmr9 all with nvidia post processing on/off with dxva on/off etc etc etc took flippin ages :eek: i've also added resolution switching to the multigroup, the list seems endless.
    Tim.
