ffdshow automatic pal/ntsc switching
Discussion in 'Desktop & Laptop Computers Forum' started by fallwood, Oct 10, 2004.
  1. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Can anyone point me to where i can find instructions on setting up girder to automaticaly run the registry settings needed to switch between pal/nstc in ffdshow. Ive seen it mentioned over at avs forums but cant find a thread with detailed instructions on how to do it. Apparently you use the dvdspy and regedit plugins to change registry upon insertion of a dvd. By the way im running theatertek and sonic decoder.
  2. groovyclam
    groovyclam
    Mar 28, 2004
    202
    It's easier to skip doing it with Girder.
    Use the free system tray utility DVDautorefresh to detect when a PAL or NTSC disk is inserted and set the registry accordingly.
    You have to set the DWORD registry entry "HardCodeForPal" = 1 for PAL disks and = 0 for NTSC disks.
    HardCodeForPal should be created at:
    HKEY_LOCAL_MACHINE\Software\Sonic\Cinemaster DS DVD\2.5\VideoDecoder\
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Anydvd will also run an external program or batch file dependant on region.
  4. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Thanks thats much easier than trying to learn how girder works. Is their any way that the registry settings can be added without the popup box appearing asking if its ok to enter the settings, kind of spoils the integrated look of my meedio front end.
  5. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Anydvd will do this, but not for dvds on a hard drive.
    Do avoid the popup, use a MS-DOS Batch File to open the reg file.
  6. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Im using batch files to run the registry entries through any dvd, do I need to enter a switch or parameter to stop the "are you sure you want to add these settings to the registry" popup window.
  7. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    Here is my batch file, I believe the switch you need is the /s. I don't get the pop up confirmation boxes with these batch files
    c:\windows\regedit.exe /s "c:\Reg\ntscenable.reg"
    c:\windows\regedit.exe /s "c:\Reg\NTSCres.reg"
    I resize to 3 x DVD resolution, so have a PAL and NTSC bat file, in conjunction with AnyDVD, that changes the PAL/NTSC setting for FFDShow, and the vertical resolution at the same time. This is the NTSC one. Hope it helps
  8. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Cheers that works a treat.
  9. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    No problem :smashin:
