ffdshow and Zoomplayer
Discussion in 'Desktop & Laptop Computers Forum' started by GRees, Nov 12, 2003.
  1. GRees
    GRees
    I've been trying - unsuccessfully - to get Zoomplayer working with ffdshow. So far I've managed to get a green screen which freezes whenever I change chapter.....:confused:
    I've tried different versions of ffdshow but I can't seem to get any joy out of them.
    Which version works best and how do you set it up to work with Zoomplayer?
    Thanks in advance
    Gary
  2. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    What video codec are you using,
    sound like Windvd, if this is the case there are a few things you have to do to get it to play nice ,
    sonic is the same, and not sure power dvd will play with ffdshow
    best place to get info on FFDshow is over at the us version of this forum
    link
    steve
  3. GRees
    GRees
    Hi Steve
    Thanks for the reply. You're right, I am using the Windvd video ( and audio ) codecs. I had a good scout around the AVSFourum and found a good thread covering just about everything you would wan't to know about ffdshow and I've finally got it working :clap:
    Not exactly what you'd call Plug and Play is it :(
    Anyway I'm off to do some tweaking.
    Thanks again
    Gary
