FFdshow and resize
Discussion in 'Desktop & Laptop Computers Forum' started by BenPremium, Sep 19, 2005.
  1. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    I've just been playing around with setting ffdshow up using a good guide I found.
    However, whereas before Theatertek was showing the DVD taking up the full screen, now it is adding borders to both top/bottom and the sides.
    I'm outputting via VGA to a Samsung LE32R41BD. FFdshow menu says that it's resizing to 1440 x 960 but it's certainly not taking up the whole screen.
    Am I doing something wrong?
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    You need to calibrate your display with the theatertek aspect ratio editor.
  3. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    Thanks for the reply.
    However, when I right click and go to Aspect Ratio the "edit" option is greyed out. Any ideas why?
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    Can you comfirm that you are playing a movie while trying to access the AR editor? It will be greyed out if nothing is playing.
  5. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    I was playing a movie but I've just realised I had it in full screen mode. When I take it out of this it lets me access it.
