ffdshow and MediaPortal
Discussion in 'Desktop & Laptop Computers Forum' started by SeriousPigeon, Sep 9, 2005.
  1. SeriousPigeon
    SeriousPigeon
    Sep 9, 2005
    150
    43
    Amersham
    +105
    Hello,
    I am new to these forums and to HTPC so here goes.
    I have done some searching for this but with little success.
    I am trying to use ffdshow to upscale DVD to 720p in MediaPortal.
    I can get it to work for video files ok. But vob files just don't work, whether they are straight from the DVD drive or stored on the hard drive.
    Can anyone help me in getting this to work properly.
    Also I am having some problems with XMLTV grabbers. When I use bleb I only seem to get some of the channels requested, which is a little annoying.
    So I tried switching to Radio Times listings, but this does not seem to include the icons for the channels.
  2. dnoon
    dnoon
    This is a good beginners guide, not directly linked to your front end, but the same priciples should apply to allow you to get going, skip to page 4. It sounds to me like you have not set teh Raw Video to all supported. Best of luck
    http://htpcnews.com/main.php?id=ffdshowdvd_1
  3. SeriousPigeon
    SeriousPigeon
    Sep 9, 2005
    150
    43
    Amersham
    +105
    Forgot to mention that I have set the raw video to "all supported".
  4. SeriousPigeon
    SeriousPigeon
    Sep 9, 2005
    150
    43
    Amersham
    +105
    Got the ffdshow sorted now, just needed to use a different mpeg2 codec and it all works fine.
    Anyone know about the XMLTV problem?
