FFDshow and Dscaler
Discussion in 'Desktop & Laptop Computers Forum' started by JohnS, Jan 31, 2005.
  1. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Anyone using it?
    I've just been bowled over by the improvement I've made to TT 2.06 with my first proper attempt at using FFDshow.
    I've just changed my Dscaler install to 4.10 and now FFDshow appears as an available filter but as soon as I select it the picture freezes. Any ideas to what I may be doing wrong.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I wonder if this is the PAL problem in another guise .. given MPEG decoders need to be told to tell FFDSHOW it needs to switch modes it seems plausible the same would have to be true of DScaler.
  3. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Hmm, thanks Robin, it may well by a Pal issue, the dvd's I've tried with TT were most likly R1's as most of mine are, it just seemed a bit odd that the settings from TT weren't just carried into Dscaler.
    Any idea what I should be looking at or is PAL a ffdshow problem at the moment?
  4. Kaz
    Kaz
    my dscaler (4.10 or 4.7 I can't remember) freezes when I select the ffdshow filter.
    ffdshow does work through my TT1.5, since adjusting it with the settings in that other recent thread.
    It also works with UK DVDs, but I think that was down to a registry change I made when I first tried ffdshow (and then abandoned it).
  5. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Thanks Kaz, its not just me then.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Sadly John I don't know where to look. The problem is simple, FFDSHOW assumes it's processing NTSC unless told otherwise .. allegedly this has finally be addressed in some version in the autumn that someone told be about but I never found it, although I've seen just today mention of one released on 22 Jan but so far not in the 'official' places.
    When playing a DVD FFDSHOW is told to do PAL by the MPEG decoder, hence the registry setting is aasociated with whatever codec you're using be it nVidia, Sonic, WinDVD etc. The issue therefore is IF DScaler provides such a mechanism where you can set it.
  7. Too Tall
    Too Tall
    May 20, 2002
    487
    Milton Keynes
    +5
    A slight aside but on the same subject.
    I recently added FFDShow and Dscaler onto my PC. But when I selected the Dscaler filters FFDShow just crashed. I was playing a mpeg4 at the time. I stop the mpeg4 and tried again but the same thing. I'm assuming this is not normal?
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Selecting the DScaler filters from within FFDSHOW is not the same thing, in that context it's FFDSHOW passing data to DScaler's filters rather than the main DScaler program passing data to FFDSHOW .. it can get confusing because part of each are used to control video processing and parts of each are filters.
    So a crash in this context is different from a crash in the context John is asking about, the cause will probably be different as well .. though I have no knowledge the filters DScaler makes available to FFDSHOW.
  9. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    When you select the ffdshow filter in dscaler (aside from my freezing picture) and then go into filter settings, it appears that most of the parameters available in the standard ffdshow config are there for us to use, including resize, sharpen etc, they are just laid out in a list and to alter the parameters you have to add a value, not like the friendly interface in ffdshow.
    So what is the parameter we have to change in ffdshow for Pal?
  10. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    As I said above, it isn't a parameter in FFDSHOW, that's the whole problem, if it were it'd be easy.
    FFDSHOW needs configuring by the program that's using it as a processor, in this case it's DScaler that's using FFDSHOW and so it's DScaler that has to tell it and I've no useful experience at all of that product I'm afraid.
  11. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Thanks Robin, a search on the dscaler forum hasn't shown any sucess at this either.
  12. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    This has been bugging me for ages. I cant seem to find the answer would be great to use fddshow with dscaler
  13. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    A post in this thread says the latest release deals with PAL/NTSC switching so maybe that'll work with DScaler too.
  14. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    That is the version I'm using anyway (I said I was new to it) but unfortunatly I've no idea where it came from though. I found it from a google search.
  15. Too Tall
    Too Tall
    May 20, 2002
    487
    Milton Keynes
    +5
    Thanks for that KraGorn.
  16. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    You might want to see if the recently released version helps at all, though JohnS' comment indicates it may well not do.
  17. JohnAd
    JohnAd
    Mar 14, 2001
    362
    London
    +4
    The recent versions of ffdshow have a very alpha facility where ffdshow can be used as a DScaler filter. I would be very surprised if you managed to get anything other than the postprocessing and noise filters to work. REsize will almost certainly cause a crash. By the way I had nothing to do with this effort on the part of ffdhow and I have no idea what they are planningto do with it.
    John
  18. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Thanks for your input John, always nice to hear it from the horses mouth.....
    Do you think there is any benefit to using the denoise and sharpen filters in ffdshow as opposed to those in Dscaler itself?
  19. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,128
    Hello John always nice to see you around these parts. What you been up to?
