ffdshow: 100% CPU utilisation when resizing problem
Discussion in 'Computer Components' started by MyMateJohn, Oct 27, 2005.
  1. MyMateJohn
    MyMateJohn
    My comp: 3700+ AMD64, 6800GT, 1gb DDR400
    I'm trying to use ffdshow with MPC, but I can't seem to resize very well. Even if I change resize to 800*600 my CPU usage hits 100%. I have attached my ffdshow config file (remove the .txt extension). I got all my ffdshow settings from HTPCnews's guide on configuring ffdshow http://htpcnews.com/main.php?id=ffdshowdvd_1
    Where could I be going wrong?
  2. DanH
    DanH
    Feb 16, 2005
    604
    +56
    Are you looking at the ffdshow CPU utilisation, or task manager? ffdshow's isnt accurate.
    What version are you using?
  3. MyMateJohn
    MyMateJohn
    looking at task manager, ffdshow version September 16th 2005.
    I can tell my comp isn't handling it properly because it is playing the DVD at half the normal speed.
  4. DanH
    DanH
    Feb 16, 2005
    604
    +56
    I had a problem that sounds similar, but i cant remember what version it was. In the end i used the latest SSE2 version, which seems to run great. (Laczos 2 resize to 1360x768)
  5. Nicky
    Nicky
    Nov 5, 2003
    179
    +5
    As a guess I think you've got the resizing algorithm set to whatever the default is - which is very CPU intensive. Somewhere in the configuration is a way to change the method - Laczos as DanH mentions is very popular and seems to be a very good combination of quality and speed.
    Apolgies is you've changed this already - the reg settings were hard to interpret.
  6. groovyclam
    groovyclam
    Mar 28, 2004
    202
    If I remember rightly the Laczos default is 4, which is very CPU intensive -> knock it down a notch or two.
