Fetch TV HD-PVR at Tesco from 04/06/2010 - [Part Eight]
Discussion in 'Digital TV & Video Players & Recorders' started by Gavtech, Oct 31, 2012.
Tags:
  1. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,009
    +6,864
    Moderator Comment
    Thread Announcement.
    Please note that Part Seven of this thread is now closed and all further posts should continue here in Part Eight.
    For reference:
    Part One is here
    Part Two is here
    Part Three is here
    Part Four is here
    Part Five is here
    Part Six is here
    Part Seven is here
    Thank you.
  2. petrev
    petrev
    Jul 4, 2007
    4,345
    TX Mendip - DHR8205: FW4.22 - M1.35Blk
    +1,015
    :confused:
    Strange things, these little boxes !
    You have to catch just at the right moment to add the bookmark from INFO and before that you have to wait a short while to press OK.
    Sorry I can't be of more help
    Pete
  3. deden56
    deden56
    Jul 11, 2010
    117
    +5
    I am still able to use BBC iplayer will I lose this soon on my smart box 320
  4. darrenandz
    darrenandz
    Nov 2, 2012
    7
    3
    New to this. Have an 8320. Has been picture freezing sometimes when exiting i player. The solution to switch off then on again. It happened last night though this time after switching off it will no longer fire up. Starts whirs, lights up then switches off again. Just repeats this spiral endlessly. I suspect this is software but what do I know. Simeon help please.
    As an aside, decided that I too would ask Shop to net for an update this week ( before my troubles). The answer now is the next month or two. Maybe I'm a fool but I assume they are doing something or why employ people just to give irritating answers!
  5. liam8282
    liam8282
    Sep 17, 2012
    Maybe we should email them en masse, or direct them to these pages so that they can see how many people still have these boxes and want something doing with them.
    What shopto email address has everyone been using?
  6. darrenandz
    darrenandz
    Nov 2, 2012
    7
    3
    If only it was so simple. Searched and searched for a live email but alas no. Had to register and use their ticket system. Took me a while to figure it but actually it is straightforward and they respond quickly.
    Any thoughts on resolving my endless switch on switch off problem?
  7. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    Have you tried pressing, and holding for 10 seconds, the Reset Button on the underside - Try it while in it's in it's most ON state, or just randomly if no joy.
    Simeon ????
    Pete
  8. darrenandz
    darrenandz
    Nov 2, 2012
    7
    3
    Tried that this morning. Before trying the start up screen would come up before switching off again but since then just a blank screen. Names Darren. Simeon was just a badly written someone! Thanks for the first thought though. Darren
  9. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,009
    +6,864
    I suspect the unit is doomed unfortunately... but also try a lengthy mains reset.
    Disconnect the unit from the mains for at least an hour.
  10. pig
    pig
    Apr 27, 2006
    101
    Yorkshire
    +28
    Probably coincidence, but one of my boxes (the oddball one that wouldn't pair up) did exactly the same for the first time yesterday. The only way I could get it to boot was to remove the network cable, after which it started up normally. Then I put the cable back in and it was OK :confused:
  11. darrenandz
    darrenandz
    Nov 2, 2012
    7
    3
    Ah if only it was on the network I could try that. And as for having it powered down for an extended period I've tried that too! Trouble is I don't think it's kaput. If it were a pc I would try booting it from a CD rather than the hard drive but I haven't the first idea where I would start with this. I have even resorted to the slap on the top a few times school of gadgetry repair. Did absolutely nothing and didn't, even make me feel better! Joking aside, any other thoughts? Darren
  12. Mike.P®
    Mike.P®
    Feb 26, 2008
    2,702
    +518
    Anyone know if its possible to change audio streams on a dual audio MKV file?
  13. jaswilliams
    jaswilliams
    Feb 10, 2011
    99
    +32
    There is a CMOS battery on the system board you could try popping the top cover off and removing that for 20 min it might reset the box to factory
  14. joshtbh
    joshtbh
    Jul 10, 2010
    160
    England
    +3
    Hi all, I got one of these today, can someone help me with this question please:
    Is it advisable to upgrade to the latest firmware? Any bugs with it etc? I'm on 4.8.03-01
  15. jaswilliams
    jaswilliams
    Feb 10, 2011
    99
    +32
    Also power supply could be faulty do you have something similar you could try
  16. movie_lover
    movie_lover
    Dec 14, 2005
    135
    +9
    I've not found a way to do that.
    Try re-muxing it with mkvmerge GUI, only keeping the language or format that you want.
    If I can't be bothered to do that, I play the file on my WDTV which can switch streams (and will let me select which subtitles I want too!)
  17. darrenandz
    darrenandz
    Nov 2, 2012
    7
    3
    Power supply running another box so that's ok. Need to be brave and try the CMOS battery - but waiting a bit to see if anyone has a thought that isn't quite so invasive first. Thanks for the thought as I hadn't considered the possibility. Darren
  18. ra11
    ra11
    Aug 14, 2005
    167
    16
    London
    hi all - just jumping onto the thread and wondering if there is a way to load Android ICS or some kind of Linux distribution?
    I've got the web access via USB operational - but its crude to say the least...
    thank you
  19. MaffyBoon
    MaffyBoon
    Mar 1, 2011
    279
    28
    Herts
    +57
    Oh don't worry its nowhere near as scarey as it sounds. Just unplug, get the case off carefully making sure you don't damage any clips & inside look for the silver coloured penny like battery. It will just pop out of its housing (use something non-metalic). Don't gouge it, just unhook it. Leave it out for a bit & pop back in. Close case up. Test it.
  20. joshtbh
    joshtbh
    Jul 10, 2010
    160
    England
    +3
    hi guys,
    as you are going through the TV guide, what is the two coloured "dots" in the upper right of the screen for please?
  21. swindonfan
    swindonfan
    Sep 9, 2012
    3
    I've had this machine for over 2 years. I've suddenly lost the wifi connection. The box just tells me that the ethernet cable is unplugged ( I've only ever used the wifi connection due to the location of my router). Has anyone else had this problem? Is it possibly a connection problem with the wifi stick in the machine. If so, how can i get in to the machine to replug it in? Any ideas would be appreciated!
  22. Jacko
    Jacko
    Sep 28, 2010
    45
    +11
    This means the guide is updating, via the Freeview signal.
  23. Ellis456
    Ellis456
    Nov 10, 2008
    20
    3
    Does anyone else get this?, when I put my box to sleep I set it so it goes into deep sleep after 10 mins before I go to bed, when I get up in the morning it's not in low power mode anymore but in the other mode, and it does this every morning yet when I get home from work it's in low power mode again. I have nothing set to record at that time so what is the box doing?, is fetch/new owner looking at my box or what?.
    Also my box since day one I have to press the standy button numorous times to get it to power up, sometimes it powers up after one press, but most times needs 3/4.
  24. giloi
    giloi
    Nov 6, 2012
    I'm getting the same issue, I'll always put the unit in low-power mode before heading to bed, but when I wake up in the morning it's no longer in a low-power state. No recordings set or anything.
    Also, I know the box is based on Linux, but has anybody else had that really annoying Fetch TV screensaver appear every once in a blue moon?
  25. jaswilliams
    jaswilliams
    Feb 10, 2011
    99
    +32
    If you are using low power mode (I don't the wife found it too annoying) it will turn on with one press but takes about 20 seconds to turn on, unless it is recording at the time, if it is recording it is not really in low power mode and will turn straight on. The fetch screen saver normally comes on if the box has some type of on screen display showing and is left such as the guide. Sometimes I have seen it come in during tv or play back. A quick power pull will clear that issue until the next time.
    Jason
  26. jaswilliams
    jaswilliams
    Feb 10, 2011
    99
    +32
    Oh and also the box turns in between 3 and 4 to update the program guide,
  27. MaffyBoon
    MaffyBoon
    Mar 1, 2011
    279
    28
    Herts
    +57
    Yeah, and do note if you don't like the screen saver you can switch it off in the settings, or lengthen the delay before it appears. It's only there to prevent screen burn in tellys... If you listen to radio shows on freeview for a long time you can end up with the same thing on the screen regularly. This can eventually cause a permanent ghosted image on the screen. :)
  28. joshtbh
    joshtbh
    Jul 10, 2010
    160
    England
    +3
    Hi all, is there anywhere I can read what sort of files I can play through the Fetch box's Media Centre function please?
    I have a Windows Server on my network which normally serves my XBMCs but it'd be great to be able to use the Fetch to play my media if possible.
  29. geoff1248
    geoff1248
    Nov 8, 2012
    I use TVersity to stream media from my PC . Works fine for video,music and pictures. The latest version of TVersity costs a little bit but the previous version is free
  30. billybo8
    billybo8
    Feb 4, 2012
    33
    +7
    Standby and recordings
    Following the return of my last box the new one seemed at first to be spot on. The kids want to record Simpsons every day and if I set individual recordings all is well. I see a recording at 17.59 and all are there as they should be. If I set series link then nothing happens at all but I seem to remember there was a bug reported with that? Has anyone got series link to work?
    Worse is that those are the only recordings that ever work. If I set it to record anything else it never happens. This must be because the box is in standby or low power standby whereas the box will usually be on when Simpsons comes on to record. I have just set a couple to try it out and it does not wake from standby. When I turn the box on the recording starts from that point.
    What are the rules around standby and the box waking up to record? The old box was garbage but it would wake up from low power to make a totally random recording once in a while so I get the feeling this one might also be faulty. Unless it is something to do with power settings. Any help appreciated as otherwise iplayer and streaming is all working nicely and I can't face another month wait while Tesco ebay go through the motions.
