Ferrite Cores ?
Discussion in 'Plasma TVs Forum' started by 008, Aug 14, 2004.
  1. 008
    008
    Nov 13, 2002
    400
    kent
    +15
    Ive just bought a Panny 42PA20 Wow what a good chioce.
    Does anyone know what to do with the supplied ferrite cores ?
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    They are only for any computer equipment for may wish to hook up, or for a camcorder etc via the front panel inputs.
    You don't need them for scarts, component etc.
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    The ferrite core should be placed on the power lead, as close as possible to the plug that connects to the display.
    It is designed to eliminate RF interference.
    They are not for use on video or audio hookups.
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    The only Ferrite cores I have ever seen go on each end of PC monitor leads!
  5. kace
    kace
    Good choice of panel 008. You wont regret it
