Ferrite core??
Discussion in 'Plasma TVs' started by Garrymol, Feb 17, 2005.
  1. Garrymol
    Garrymol
    Feb 3, 2005
    42
    Wirral
    Exited or what .
    Assembling pw6 as we speak, yes ive now got all the gear.
    However reading manuals i dont understand ferrite core bit. also when im connecting quintro will scarts go in any slot or are there differnt ones for differnt components.
    iam trying to connect terrestial freeview and dmr e50.then from quintro into js rgb to vga converter.
    ASalways any help is appriciated.
    Garry.
  2. Setch
    Setch
    Jan 31, 2005
    71
    9
    The ferrite core should be attached to the power cord, as close to the panel end as possible. You normally get a cable tie to secure it.
    Setch
  3. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    Without getting the manual out..........................i'm pretty sure there not needed unless you are using the panny speakers or connecting a laptop..................................mine are in a cupboard somewhere.
    cheers,tam
