Ferite attachments supplied with PW7 Plasma
Discussion in 'Cables & Switches' started by PannyAdams, Dec 17, 2004.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    Does anyone know the reason for the Ferite cable attachments that come with the Panasonic PW7 Plasma?
    Should they be put onto quality interconnects?
    What happens if you have flat interconnects as they only fit round cables?
    BJ
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The Hitachi 5300 has them too. I would guess they are there to stop the cables picking up stray signals from the plasma panel and feed them back to the amplifier stages. If a manufacturer goes to the expense of an extra component, it's generally because it's needed. In your case, it's either a bigger ferrite ring that's required or thinner cable.
