Can anybody confirm that the above works for a ferguson television.
To program the remote control unit using a 3 digit code:
1. Turn your TV on.
2. Press TV on your Sky remote control handset.
3. Hold down SELECT and the RED button together for about two seconds,until the red light on the Sky remote control blinks twice.
4. Key in your 3 digit code selected for your brand of TV from the table below The light on the Sky remote control should blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
5. Press the STANDBY button on your Sky remote control. If your TV switches off, press SELECT. The light on the Sky remote control blinks twice. Now try the other functions.
6. Repeat if necessary using another code.
Codes for Ferguson tv :
0293 101, 363, 221, 218, 033, 315, 137, 266, 371, 220
Cheers,
Realslimcookie
