Ferguson LDVD220
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by jpsboro, Jan 21, 2005.
  1. jpsboro
    jpsboro
    Hi, just bought a portable dvd player and need a hack as they are not many available for any Ferguson dvd player let alone this one........
    Please help
    thanks
  2. jpsboro
    jpsboro
    Surely someone must know.................... :)
  3. jpsboro
    jpsboro
  4. thegaj
    thegaj
    Found this while looking for reviews. (my mum just bought the ldvd200)
    I havent actually tried it yet
    1. Press the Open button on your remote control to open the drive tray
    2. Press the Setup button on your remote control
    3. Press the Right button on your remote control
    4. Press the Right button on your remote control
    5. Press the Right button on your remote control
    6. Press the 9 button on your remote control
    7. Press the 6 button on your remote control
    8. Press the 5 button on your remote control
    9. Press the 3 button on your remote control
    10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    11. Press the Setup button on your remote control
    Hope it works TheGaj
    P.S. here's the address just in case http://www.dvd.reviewer.co.uk/info/multiregion/full/Audiovox1708.asp
  5. ramskil2
    ramskil2
    I have tried this hack and it doesnt work ! Any one any idea please!
  6. jpsboro
    jpsboro
    For the Ferguson LDVD220 :
    Turn DVD on
    Open Disc Tray
    Using remote type 81328
    This should then show "Region 2" on screen
    Hit "Enter" key on remote till you get to "Region 9" (Multi Region)
    Close Disc
    It works on mine so ggod luck :cool:
  7. 948golf
    948golf
    I used the Audiovox d1708pk hack on my Ferguson ldvd200. It successfully got me into the protected set up menu to alter the region code. It is also listed in www.totaldvd.com
  8. ikendal
    ikendal
    ldvd220 workd a treat thank you.
    can any one help with a ferguson?? sd-22vb?
