seafoodmix
these fence spraying kits which are about £25 from the usual brands - has anyone used them or should i stick to the brush
But the two separately. You can buy pump up spray gun for £5 in Wilko and use creosote, it stops wood rotting.
there is a creosote substitue available from wickesCreosote is no longer available, hasn't been for some time.
Personally I prefer to use a fence preservative such as:
http://www.greenfingers.com/superstore/product.asp?dept_id=200386&pf_id=FP0022D
