Female banana plug connector .. is there such a thing?
MEE2day
Hello,
I have all of my speaker wires within the wall, however. 2 of the speaker wires aren't long enough to put the speaker stand where I want it to be.
What I'm looking for is to find a way to extend the length of speaker wire without soldering as I'm afraid this might affect the speaker performance.
I'm currently using Monoprice Access Series 12AWG CL2 Rated 2-Conductor Speaker Wire with Monoprice Gold Plated Closed Screw Type Speaker Banana Plug.
Is there a pre-built cable with same quality that has a female banana plug connector at 1 end and a male connector at the other end? Or even better, are there female to male banana plug connector jacks out there so I can use the same type of wire i'm using inside the wall?
ashenfie
I don't believe there are, if you happy to simply not purchasing a longer cable then these connectors sign do the job.
Amazon product
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
