Felt mask on DIY screen - how to attach?
Discussion in 'Projectors, Screens & Video Processors' started by Snoopstah, Jan 5, 2005.
  1. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Finished constructing my DIY screen for my first projector tonight, and I'm well chuffed - turned out way better than I could have hoped, not a wrinkle to be seen!
    However, I want to put an inch-wide mask around the edge, but I'm not sure how best to attach the felt to the screen. Staples feel as though they might reflect too much, and glue seems rather messy.
    Any tips or suggestions?
    Cheers!
  2. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    829
    Derby
    +49
    There's always doble sided sticky tape
    steve
  3. Alaric
    Alaric
    Mar 12, 2001
    1,759
    Peterborough, Cambs, UK
    +149
  4. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    I think I'll just go with double-sided tape - cheap, simple, can't believe I didn't think of it! :)
    Cheers!
  5. Digger
    Digger
    Dec 31, 2003
    4,385
    World Wide Supermarket
    +205
  6. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    201
    +6
    I used copydex to fix mine, you only need the smallest pot, about £4 for 125ml although there may be smaller sizes - 50ml is in a tube
    You can get it from focus diy even though they didnt know they had it when I asked until a more senior assistant pointed it out, it goes off in about 10 mins but you can move the fabric for a short while after first applying so position is not critical like tape or contact adhesive
    its a white pot with a red lid with brush fixed inside the lid if you are looking.
    http://www.ryman.co.uk/Copydex-Adhesive-with-brush-125ml-Bottle-0625102293.asp
  7. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Another nexnix flok user here :smashin:
    Very good, just like a velvet smoking jacket :smoke:
    Captain Benefit.
  8. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Thanks guys - ordered the Nexnix flok yesterday lunchtime, arrived this morning, fitted it this afternoon. Looks amazing!
