Feeding A Toshiba PF3
Discussion in 'Xbox Forums' started by cluster, Mar 13, 2006.
  1. cluster
    cluster
    Hi i have just purchased an xbox 360 and want to use component cable to feed my Tosh PF3 (component). What do I lose not having an HDTV screen? I am presuming the picture quality will still be good even though there will be some down scaling? going on!
    Sorry for being vague just want to get the best out of the 360 and the 36" screen.
    Cheers all!
  2. ifrank castle
    ifrank castle
    Jul 2, 2004
    181
    Dover, Kent
    +38
    i might know the answer to this question for you, not sure why no one else has replied yet, but here's mine two pennies worth:-
    i'm presuming (correct me if i'm wrong),that you have a crt tv, like a toshiba 36zp46p. on this presumption, your tv only goes up to 480p, now the 360 can do 720 (or 780) and 1080 (all these figures are lines of resolution). in other words, your losing out slightly (or greatly, whichever way you look at it) in terms of picture quality.
    if you had a hdtv then you would be able to play games at a higher resolution compared to what your playing at the mo.
    hope this helps??
  3. boylucifer
    boylucifer
    Dec 28, 2005
    580
    28
    +65
    I have 32zp48 (I think), i.e. Toshiba PF3, and play 360 through component on it, it displays in 480p, which means less lines than 720p. Graphics quality is ok, but to be honest I think some of the dark areas remain too dark, and i've tried loads of pic settiings.
  4. corh5
    corh5
    Feb 6, 2004
    535
    +13
    i have a 32ZP38 (PF2), and i think the picture is cracking, however i have only ever seen the Xbox 360 running hi-def on the Pod machines. Screens far too small to make a proper comparsion.
    I really have itchy fingers to get a hi - def screen but am holding on till Sky HD is released, thats when you'll find out what screens have gremlins and incompatibitly flaws.
  5. chuwright
    chuwright
    Oct 26, 2003
    96
    London
    +5
    I have PF2 32ZP38, stopped working in November for TV and Sky, but works for component. I bought a Philips 379830 LCD to replace it, to be honest the picture on the Tosh was fine, the pic on the Philips is bigger, better, but I wouldn't say £2000 better. The Tosh is still in the house facing a wall. I'll sell it to a TV repairman or something.
