Fed up with the Denon 1910
Discussion in 'Blu-ray & DVD Players & Recorders' started by philips, May 30, 2005.
  1. philips
    philips
    A few month back I bought a Denon 1910 to go with my Loewe Xelos 32 LCD.
    Conneting over DVI is less than impressive, borders appear around the edge, black borders at the top and bootom lead to poor contrast against the actual picture and blacks in the picture are washed out.
    All in all the picture is better over scart!!! I can at least control the ratio of the screen over scart.
    Fed up - anybody come across similar problems or have solutions.
    Otherwise my next stop is to sell the player and to never buy Denon again. :mad:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    DVI offers less controllability over the picture for some reason. I do tend to use the overscan facility on my projector (to nip off the black borders) more often using DVI vs component.
    I suspect this is not a problem with the Denon alone.
    Actually, it's probably more of a "feature". For example - 1.85:1 movies, strictly speaking, should show very small borders on a 1.78:1 (ie 16:9) screen...PJ :)
  3. paulfoley
    paulfoley
    Sep 17, 2003
    3,402
    Hants
    +104
    If you are upconverting to 720P or 1080i then you will have no ratio control. Its not a fault of the player, its doing what its supposed to i.e. 1280 X 720 is a fixed widescreen 16:9 format. If you want ratio control over the DVI picture then you will have to turn the upconverting off.
    As for the poor blacks have you setup the TV correctly i.e. tried Avia or something similar ?
  4. Loewe
    Loewe
    I am more than happy with 1910, DVI and (Sharp) LCD. No borders when DVI-input is set to digital AV. Except of course the natural borders on top and bottom of all films wider than 16/9 (most films). The 1910 has gamma-adjustment that is nice if you want more details in dark scenes!
    Check if the player needs new firmware! Needs to be ver. 1.10 or higher.
