Fed up with AMD
Discussion in 'Desktop & Laptop Computers Forum' started by Sinzer, Jan 17, 2003.
  1. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    Another AMD CPU blown for me (4 chips blown over 18 months with 2 motherboards) this time my new thermaltake 7+ slipped off the clip when turning it upright. I think I have had enough of this bang for buck processing power and will now defect over to INTEL.
    Anyone got any recommendations for a P4 motherboard, I was looking at the Asus P4PE, really want something that is fairly cheap and reliable, not after huge power. Budget is about 200 quid I believe a P4 2.0 Ghz is about 100 squids?
    Also, anyone have any experience with the Globalwin 802 case and a P4 mobo??? I remember when I first set it up, it came with some funny mod that mentioned something about Pentium mobo's am I getting senile? Or can I just chuck in the P4 mobo without any pfaffing around?
  2. acs1
    acs1
    Aug 28, 2002
    52
    Hove
    Funnily enough I have a P4 2ghz running on a Gigabyte GA-8IEXP motherboard, this has USB 2, RAID connector, onboard sound and network all on the motherboard.
    Also have this all in a Globalwin 802 case, temps are about 32c at this moment
    Gigabyte m/bs are so stable and blue!!!!! I have not used the P4 Asus board but they have rave reviews.
    Adam
  3. nwhome
    nwhome
    A mechanical failure this time then?
  4. HMHB
    HMHB
    Nov 11, 2001
    26,724
    Nottinghamshire
    +5,490
    I've given up with AMD mainly because of VIA chipsets. I have 3 systems with VIA chipsets and I can't get the 4in1 drivers to load properly on any of them. I've had so much trouble that I just won't buy another MOBO with a VIA chipset
  5. m3rlin
    m3rlin
    have a look at the sis chipset
    i used via before, but shift to sis as i upgraded to a athlonxp.
    It works good for me and they are much cheaper.
    Yeah and be sure to fix the fan welll, lol!
    (thats things that happens....)
  6. Desmo
    Desmo
    Jan 4, 2001
    14,169
    Braintree, Essex.
    +5,831
    Wait, I have a cunning plan. Buy a mobo without a VIA chipset ;)
  7. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    I'm using an Intel D850EMV2L board in my '802 and it fits fine.
    2.25GHz. chip (I think!)
    Current temp according to Intel active monitor:
    CPU: 36c System: 38c System fan: 2600 rpm.
    Rock solid mobo. Pretty quiet as well. No northbridge fan etc.
  8. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    Get an Nforce combo pack, I got an Nforce mobo and Ti4200 pack and get no problems whatsoever with nvidia's own drivers.
