Favourite cables
Discussion in 'Cables & Switches' started by Freddie, Aug 1, 2003.
  1. Freddie
    Freddie
    I'm getting to the stage where I'm relatively happy with all the big lumps in my hc setup, amp, front speakers, etc and am now starting to look into decent cables.
    My set up is as follows, M74i , M7c2, Marantz sr6200, Rel Q50, Samsung 709 dvd, phillips 32inch widescreen and three cheap phillips surround speakers to the rear.
    I have bi-wired all three fronts using Cabletalk talk 3, but am looking for advice regarding decent scarts/digital (both coax and optical)/sub cables.
    The scarts/coax need to be 3m long approx and the sub needs about 2m of cable.
    IXOS and QED always crop up and I was after your views regarding these and other makes and the associated pro's and con's.
    Thanks for you time, Fred
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Profigold by Bandridge are OK cables reasonable performance for the money and for odd lengths etc i would use lektropacks custom service.
