Faulty Yamaha RX-V640RDS ??
Discussion in 'AV Receivers & Amplifiers' started by acanning, May 25, 2003.
Tags:
  1. acanning
    acanning
    Mar 11, 2002
    109
    16
    Hampshire
    Dear All
    Has anyone come across this before?
    I have just taken delivery of a Yamaha RX-V640RDS upgrading from a DSP-E800. I plugged the new amp in using the main pre-outs to my Meridian gear in the same way as I did with the E800. However, two faults, which may be related, occurred. Firstly, when turning the volume up quickly (holding the volume-up button on the remote down from dead quiet to pretty loud) I get some loud cracks coming through the main front speakers. I mean loud too – I was fearful of damaging them. This happened a few times but not every time. Secondly, if I hit the mute button the sound naturally disappears but when I hit the mute button again the sound only returns through the centre and rear speakers – ie not through the main front speakers. I have to then touch the volume button, either up or down, in order to reinstate sound through the main front speakers.
    These faults suggest to me that there is probably a problem with the Pre-Out output stage on the RX-V640RDS as it has never happened when using the DSP-E800. I’m sure there is nothing wrong with the Meridian gear. In fact, I’ve now returned to the E800 and all is well again. I’m assuming that when using the pre-outs from the RX-V640RDS the amp should function as though I was using the onboard amps.
    I think I will be exchanging the RX-V640RDS but any comments would be helpful.
    AC
  2. backtothefuture
    backtothefuture
    hm yes sounds like a short somewhere in your Yamaha
    get a replacement :)
