dtobin
I'm 99.9% sure that I know the answer to this question but as a last effort I'll ask it anyway.
Do you think my HTC Touch HD is faulty?
It will not connect via the supplied USB cable. I can use it to power the phone but my pc will not see it at all. I have tried:
1) Software re-install
2) New cable
3) Soft reset
4) Hard reset
5) All the above using a different pc
6) Different phone - this worked fine on both pcs.
As far as I can tell, it must be a faulty port on the phone.
Any other idea?
2) New cable
3) Soft reset
4) Hard reset
Any other idea?
