Faulty Toshiba 32ZP18?
Discussion in 'Televisions' started by Oakey, Aug 19, 2003.
  1. Oakey
    Oakey
    Aug 4, 2002
    526
    +6
    I'm just running the THX setup that comes with the T2 disc and on the 16:9 test I noticed the left side of the larger rectangle was missing. I used the horizontal width and position settings in the menu to change this but when I reduce the size to fit the rectangle on screen, I notice that it is curved. Do I have a dodgy TV? Anyone care to explain what this curved line means? Thanks
