Faulty Thompson 44RW65US
Discussion in 'TVs' started by m1k3, Apr 20, 2005.
  1. m1k3
    m1k3
    Could anyone please help me out,
    I have a Thompson Scenium 44RW65US which up till now has been a reliable set.
    However the set has developed a fault,the screen is blank and when i try to switch it on the LED flashes a couple of times then a brief pause then continually flashes.
    I take it this could be some kind of fault code.
    Any advice will be greatly appreciated. :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    20,350
    Lanarkshire
    +1,954
    It is "some kind of fault code"
    The number of flashes and pauses between and led colour indicate roughly in which part of the circuit the fault lies.
    Reference to the service manual will tell a technician where.
    It is not really a diy job......suggest you call out an engineer.
