Faulty player or AV Amp!
Discussion in 'Blu-ray & DVD Players & Recorders' started by cygnusx1, Jun 6, 2005.
  1. cygnusx1
    cygnusx1
    I have a pioneer dv-656a connected to a Denon avr-1905. The connection to the av is a coax digital cable. When playing retail dvd's(i have no other type) the sound goes wierd, you can hear the ambient/background noise fine but the spoken sound goes completly or becomes crackly. This does not happen all the time,or in the same place if you replay the dvd. I could use some help as to where the problem may lie.
    cynusx1 :lease:
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The signal from the player is not split between channels until it gets to the amp. Problems with speech suggests an issue with the centre channel and assuming you are using a center, I would be looking at the amp as the culprit. However it could be poor mechanical connection of speaker cable or something simple to correct by a dealer.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Based on the description I tend to agree that the amp or the speaker (or the connection between the two) is at fault.
  4. cygnusx1
    cygnusx1
    Thanks Reiner & Cable Monkey. I have checked the center speaker cables at both ends. The connections to the center were a bit loose so have tightened. Will see what happens . The speakers are JBL SCS-178, do you know of a common problem with the center of this model?
    If the problem still exists, how can I isolate where the fault lies? I bought the amp and the speakers from a internet store so cannot go to the dealer.
    cygnusx1
  5. Moonsoon
    Moonsoon
    I'd bet my money on the speaker or faulty soldering in the electric pathway of the signal.
    If tightening the cable connections does not yield a result, try putting it into another speaker position that worked properly, i.e. left surround and see remains or is gone.
  6. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Yes, as said, just swap one working channel with the faulty one and see which if either is going. If the speaker that was working then cuts out it's the amps center feed.
