Faulty iScan Ultra Maybe?
Discussion in 'Projectors, Screens & Video Processors' started by themmings, Jul 9, 2004.
  1. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Hi folks.
    Is there any iScan Ultra experts out there?
    I've had mine for about 18 months. I run my SKy+ box through it and output the signal to my Pioneer 433MXE plasma screen via VGA high quality cable (sky+ goes out via VGA and then gets converted to component via my JSimms box).
    I used to be very happy with the image via sky, but recently I've not been happy with the picutre. Basically when you watch football or moving images you get this horrible comet trail, stiller images don't seem what they used to be either (more pixelated and trails to a certain degree too).
    I run my Arcam DVD player (DV88) through the iScan Ultra and the image seems fine. But Sky is poor.
    The other thing that makes me think there's a fault with my iScan is that I can't pull the 'Picture' function up on the display window any more (either by remote control or manually on the front of the unit).
    The thing that puzzles me though, is that it is giving me some functionaility - i.e. toggling and passing a signal from both component 1 and component 2 (sky source / DVD source)????
    I'd of thought that if it was to go pop - the whole thing would go pop and you'd not be able to run any signal through it.
    It definately seems to have lost some processing 'omphhh'.
    Any help would be greatly appreciated.
    Thanks, Tim :)
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    themmings
    What does the 433MXE think its seeing - Interlaced or Progressive; possibly the signals getting through the box but no processing is being applied.
    Use the 'Display' button on the MXE remote and the screen will flash up info on the signals its receiving.
    Best regards
    Joe
