Question Faulty HP N54l - red light :( - sellable/parts?
Discussion in 'Networking & NAS' started by originalsauce, Aug 25, 2017.
  1. originalsauce
    originalsauce
    Dec 23, 2009
    472
    +30
    Hi all,
    so i have been re-setting up this server, removing loads of dust and it seems i have buggered it !
    i removed the graphics card a few hours ago when it was shut down and powered it on... i then after a while replaced the blanking plate and it now just displays a red light at the front..
    tried loads of reseating cables/removing more dust, using one stick of ram , no sticks of ram, no HDD's... leaving cmos out... out of ideas tbh!
    TL:DR: is any of this " faulty" server sellable? PSU perhaps? only problem is i don't know what works but the PSU FAN does work..
  2. mickevh
    mickevh
    Apr 30, 2007
    7,223
    West London
    +1,736
    Does it beep at all - some PC's have "beep codes" that give hints as to what's broke.
    May be worth downloading a copy of the hardware manual from HP.
  3. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,320
    +1,278
    A quick Google and red seems to indicate that there is a motherboard issue.
    You could try selling for parts but given you can pick them up fairly cheap you shouldn't expect much for a "broken"one
