Question Faulty HDD on Sony RDR-HXD870
Airlane1979
I recently bought this unit used, as I had one a long time ago which was very useful. However, it shortly afterwards began freezing the picture on hard disk playback. Is the only option a like-for-like replacement of the drive? Ideally, I'd install a SSD but I suspect that's impossible. I have the service manual and see that I'd need to buy a service remote. Is an identical new drive still available?
If this would be both difficult and expensive, I'll just use it to record on DVD-RW.
Clem_Dye
A suitable drive is probably still available, even second hand maybe. It depends if Sony, like Panasonic, tattoo their drives with a unique identifier which makes it nigh-on impossible to swap.
Upvote 0
Gavtech
Administrator
You should try a drive re-format first.
Upvote 0
Airlane1979
I'm not sure how to do that. The manual does offer this in the System menu but only when a hard disk error code is displayed. It's not. This is confusing, as clearly the drive is not working properly but there's no option available to format it. Is there another way to format the drive?
Upvote 0
LG CX Best Picture Settings
