J
jules666
Hi.
My 5 year old Grundig has just developed a fault. It's not serious but is a real pain! The remote will bring it out of standby, but that is all-can't change channel or volume level!! Luckily it was on the sky option so I can still use the sky remote for changing channel. I've changed the batteries, so it isn't that. I don't appear to have a red light showing on the tv or the remote for the sensor, so is it the remote sensor? Can anyone make any suggestions as I don't want to buy a new set just for this? Oh and before anyone suggests the sky remote, it doesn't work with the tv-none of the codes activate it!
