Faulty board for Panny ?
Discussion in 'Plasma TVs Forum' started by Davidgilmour, Sep 14, 2007.
  1. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    782
    Amsterdam
    +15
    I just received a VGA board for my PW7 and installed it (twice) but I get a purple colour on it when I attach my PC with it.
    Anyone got any ideas? faulty board of am I doing something wrong?
    [​IMG]
    [​IMG]
  2. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    What signal are you feeding it, component, RGB???
    It may need chenging either at source or on the panel.
    Cheers.
    Vileda
  3. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    What's the VGA cable like? have you another lead? I had some colour problems when I connected my panel (admittedly a PW5) up to my PC ...not purple though?
    Also check what type of monitor the PC is outputting to, see if there's a setting for a PW7?
  4. vileda
    vileda
    Oct 15, 2004
    401
    Oh, and of course check the cable as it looks as though there's no blue in the pic.
  5. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    782
    Amsterdam
    +15
    thanks all, it was the selection, it was on component and had to choose RGB :)
